removing exhaust question
h100rr
Posted 2012-01-26 2:33 PM (#106179)
Subject: removing exhaust question
Maryland
Do I have to left the bike to remove the exhaust? Thanks
taz456
Posted 2012-01-26 2:39 PM (#106181 - in reply to #106179)
Subject: Re: removing exhaust question
I was able to get the pipes off of mine without lifting the bike to change the tips.
h100rr
Posted 2012-01-26 2:41 PM (#106182 - in reply to #106179)
Maryland
thanks,
Lotzafun
Posted 2012-01-26 3:19 PM (#106186 - in reply to #106179)
Rockford, IL
While removing the mufflers is pretty easy......setting it on the tipovers will make it even easier. Drop on the right tipover for the left muffler and vice-versa for the other.
Godspeed
Posted 2012-01-26 6:28 PM (#106198 - in reply to #106179)
Denver, Iowa
Where the two head pipes enter into the crossover pipe...that was the hardest part of my exhaust removal. Also, check your crossover pipe to be sure there is no exhaust leak. I used an exhaust-putty(not silicone) type of stuff (from NAPA, I think) on all of my couplings to insure I have no exhaust leaks.
To answer your original question... no.
Edited by Godspeed 2012-01-26 6:29 PM
charlie
Posted 2013-01-26 11:30 AM (#130110 - in reply to #106179)
Danville NH
the panal just about the exhaust does then just pop off with pressure clips ??
cw1115
Posted 2013-01-26 11:00 PM (#130151 - in reply to #106179)
Ruskin, Fl
There are 6 or 8 screws, I forget, than a few clips. I have taken them on and off several times. I either get it off (or on) super easy or I have a bitch of a time. They require a little finesse to get them to clear the saddlebag doors. I wish somebody would make a video of that.
They must come off to remove the mufflers.
Edited by cw1115 2013-01-26 11:01 PM
atvtinker
Posted 2013-01-27 8:56 AM (#130157 - in reply to #106179)
Grand Cane, LA
Also to make removing the mufflers a little easier, find a strap wrench. This way you can twist the mufflers downwards to clear the mounting bolts without having to take the back bracket loose (the one under the back lights). You will also have to raise the bottom edges of the back body panel around the back lights to get that side panel loose because the back tab is engaged with it.
charlie
Posted 2013-03-21 9:33 AM (#132406 - in reply to #130157)
Danville NH
ok so the pannels under the side trunk doors are screwed on ?
Posted 2013-03-21 10:31 AM (#132407 - in reply to #132406)
charlie - 2013-03-21 7:33 AM
Yes, if you open the saddlebag doors, you will see the screws.
conn-e-rot
Posted 2013-03-21 10:46 AM (#132408 - in reply to #106179)
Conneaut, OH
screws and clips
