| How difficult is it to install cams in a 106 Freedom engine. |
Posts: 8144 New Bohemia, VA | Banjo - 2011-12-11 6:29 PM
depends on the year --- KevinX can give some details.... |
Posts: 169 The Vic Shop - Central Iowa | Banjo - 2011-12-11 5:29 PM
How much skill do you have? Where do you live? What year bike? |
| Banjo - 2011-12-11 2:29 PM
That's very difficult to answer. It all depends on your experience, patience, available tools, etc. I've done 3 of them so far but I have a lot of engine experience and a perfect shop setup with all the tools and a lift so for me it was easy. You have to consider the fact that if you make even one mistake the results can be catastrophic including possible crashed valves, oil leaks and worse. If you have the wherewith all then by all means go for it otherwise find someone who has done it before and at least get him to supervise. Another consideration is that the job is in part not done by the book and entails prying up the upper frame member. Having the shop manual is imperative particularly in regards to setting the cam timing correctly. If I can help let me know.
Marc |
| marcparnes - 2011-12-12 10:40 AM Banjo - 2011-12-11 2:29 PM How difficult is it to install cams in a 106 Freedom engine. That's very difficult to answer. It all depends on your experience, patience, available tools, etc. I've done 3 of them so far but I have a lot of engine experience and a perfect shop setup with all the tools and a lift so for me it was easy. You have to consider the fact that if you make even one mistake the results can be catastrophic including possible crashed valves, oil leaks and worse. If you have the wherewith all then by all means go for it otherwise find someone who has done it before and at least get him to supervise. Another consideration is that the job is in part not done by the book and entails prying up the upper frame member. Having the shop manual is imperative particularly in regards to setting the cam timing correctly. If I can help let me know. Marc Yes all of what has just been said. There is more to it then meets the eye.
| Kevin X did mine. I watched and this is a job that I am glad I left to a professional.. By the way well worth having the cams done.. I added the Atom Bomb exhaust and love every mile of riding. |
| I was just curious. I'm not going to tackle that job myself. I just wish KevinX still did cam party's in Norcal. |
Posts: 1340 Gainesville Fl Home of the Gators | Banjo - 2012-01-02 9:35 AM
Get me 3 more people, and I'll come out to Nor Cal |
Posts: 94 Las Vegas | How about Vegas? |
Posts: 1340 Gainesville Fl Home of the Gators | DetroitDetomaso - 2012-02-13 3:01 AM
How about Vegas?
Sorry man, but I don't do steel frame bikes on the road |
Posts: 935 Rockford, IL | Kevin-
I'm kinda thinking he might have possibly meant Las Vegas? |
Posts: 1340 Gainesville Fl Home of the Gators | Lotzafun - 2012-02-13 9:28 PM
Kevin-
Oh...umm.....Yea......OOOPPPSSSS!!!! Get me a group of bikes together, and I am totally there. Not gonna do July/August this year though*LOL* |
