| DO any of you have a problem with the upper wings opening up when riding?
Can these be adjusted tighter? |
Posts: 8144 New Bohemia, VA | TRELL - 2011-12-09 8:14 PM
I took mine off, but I think you can tighten the pivot. |
Posts: 3773 Pittsburgh, PA | never ever had a problem with mine on both visions. |
Posts: 494 Akron Ohio area | double post
Edited by bigfoot 2011-12-09 8:07 PM
Posts: 494 Akron Ohio area | No problems at all with the uppers. |
Posts: 161 Oregon. | No problems mine. |
Posts: 72 Chino Valley, AZ | No problems here. |
Posts: 133 , AR United States | Mine haven't moved, but I think I read once that if they move you can tighten the center screw. Just don't tighten it too much or the plastic may break.
Edited by BillyJoe 2011-12-10 1:37 AM
Posts: 374 Tucson, AZ | My left one moves...tried to tighten the screw, and no help....so I just push it open occasionally...
mike |
Posts: 48 Simpsonville, SC | Mine move sometimes, haven't tried to fix it yet, will watch the replies on this thread |
Posts: 520 Simi Valley, CA | Only when I retract the wheels and take off |
Posts: 741 Central New York | My 08 had one loose and one tight right from the factory. The dealer said it wouldn't tighten. I research a parts fiche and learned there is supposed to be a fiber 'friction' washer in there. I went back to the dealer and told him to remove the fairing and check it. He did. Washer was missing from the factory. He got one and put it in and all is grand.
So check for the 'friction' washer. |
| In the parts look up you can see washer but there in no p/n for it
Posts: 83 Bolivar Missouri | My left one was moving . Tighented it up via 2 screws it hasn't moved since if memory doesn't fail it is a torx . |
| tighten the two torx screws to no avail. now will try middle screw. |
Posts: 337 san antonio, tx | I haven't had a problem yet, but I'm wondering if using spray type waxes can cause it to happen. The spray might be getting in and reducing the friction?
Just a thought. |
| TRELL - 2011-12-10 2:28 PM
What middle screw? Mine only has the two little torx screws. And yes, my left one opens up on me, but the right one is fine. |
Posts: 741 Central New York | john frey - 2011-12-10 12:50 PM In the parts look up you can see washer but there in no p/n for it Should be: 5521735 You may also need a: 5436790 |
Posts: 554 2 mi from Jim Beam n KY | Remove the cover and tighten the bolt on each one.
Edited by DannyB 2011-12-13 3:58 PM
| DannyB - 2011-12-13 3:57 PM
Can you be more specific... what cover? what bolt? Is this a 5 minute process or a 5 hour process? |
