| I have had my bike for 3mo. now and both side badges are out. do they not last any longer than that? |
Posts: 133 , AR United States | I've had my 2009 for 19 months and both still work... I think. |
Posts: 639 Tri Cities, WA | Hmm there is some thing wrong then with yours. I have had mine and know many other vision owners like myself who had our visions since 2008 and our side lighted badges are still running strong. I would have your local mechanic look at it. |
Posts: 3773 Pittsburgh, PA | it was common for the left one on 2008's to fail (according to my dealer) but both NO.. |
Posts: 3006 San Antonio, TX | The only time one mine went out was when the dealers mechanic forgot to plug it in after doing some work on it. Almost three and a half years and over 27,000 miles later they still light up every time.
I would hope to think that you did not end up with a bad pair.
Ride Safe |
| There LED lights that should burn for a good 1000 hours. You must have blown a fuse or did something you shouldn't have. |
Posts: 324 New Orleans, La, | My VV is an 08 with nearly 50K and both badges light every time even after leaving the ignition on accessory till the batery discharged nearly completely at least 3 times. I don't recommend you try this at home, or anywhere else, but they have never fialed, sure can't say the same for the radio. |
Posts: 763 Anderson, IN (48mi NE of downtown Indianapolis) | 30k miles on '08, no problems.
The horn is on the same circuit. Check to see if it still works. |
Posts: 266 Hartland, , WI | 2008...both still working...original. |
Posts: 785 Mt. Vernon, WASH. | Check the connectors, when something electrical was working and now suddenly isn't 99% of the time it's a loose plug or connection, or you somehow got it wet and it's not getting current.
They are LEDS and draw microamps of power, they are like a 13 year old boy, it doesn't take much to get them excited
Edited by SYNSTR 2012-01-16 3:54 PM
Posts: 3773 Pittsburgh, PA | when my left one failed i took it apart and found out that water was getting in there and caused the failure. |
Posts: 1290 Ruskin, Fl | Left side crapped out on my first '08. Replaced no charge. My current "08 has had no problems with that so far. |
Posts: 8144 New Bohemia, VA | any fix on this Trell? |
| I've my 08 for 2 1/2 years and both work fine. |
Posts: 51 lakes region, NH | My left one just popped right off the bike one night riding home and the light was just dangling bu the wires. It's a 2011 and it was covered under warranty no problem. |
Posts: 125 Kerrville Texas ( now a homeowner on six acres) | Baught ours in late sept. of 07 now with 36500 miles both still burning brightly.
LOL Smadge |
