Posts: 277 Apopka, FL | VMC member, "I DONT CARE" (aka: John Webb) has assembled a backing/mounting plate under a Kuryakyn brake pad. His design is solid and is an EASY install. If any find their brake pedal too small (most Vision riders), he has the solution and for only $49, it is a bargain! He sends it with a SS bolt already too. Check out my BEFORE & AFTERS below. Thanks John for solving the riddle of how to find the Vision brake pedal! He also has pedals for most of the lesser Victory bikes! LOL!
 (photo(2).JPG)
 (photo(4).JPG)
Posts: 1117 Northeast Ohio | Do you have a link on TheVMC for this? I have been looking and searching for 15 minutes now. |
Posts: 102 Jal NM | Now that's what I have been looking for as Ihave missed the large brake pedal from my old nomad. Thanks for the info DrDecay. |
Posts: 277 Apopka, FL | Go to the Classified section of theVMC.com and SEARCH for Brake Pedal. <a href="http://forums.thevmc.com/bb/forums/thread-view.asp?tid=100094&posts=2">http://forums.thevmc.com/bb/forums/thread-view.asp?tid=100094&posts=2</a> <br />
Edited by DrDecay 2011-11-30 12:55 PM
Posts: 880 Orlando, FL | Funny, I've never been dis-satisfied with the Visions brake pedal. Having ridden crotch rockets for years I don't expect or need a large pedal. HD started that trend to give the impression of a "manly" brake. First, you should use your front brake most of the time. I only use my rear brake about 20% of the time at most. THe couple of times I've had to make a "panic" stop I've not had an issue using both brakes. |
Posts: 763 Anderson, IN (48mi NE of downtown Indianapolis) | Even though that brake pedel does look good and fits the Vision, I prefer the small stock one. My toes get snagged on bigger pads in a panic stop situation. I suppose if the Vision came stock with a pad I would just make myself get used to it. |
| That is the same pedal that on my harley. |
Posts: 3773 Pittsburgh, PA | I actually perfer the oem one as well. In 3.5 years ive never had s issue using it. |
| here is one 3" for $19.95
Edited by john frey 2011-11-30 5:28 PM
 (3 inches long.jpg)
3 inches long.jpg (27KB - 4 downloads)
Posts: 79 Michigan | Like the 3" peg. What brand is that? |
Posts: 8144 New Bohemia, VA | I've used mine for 4 year now without issue, but I still want to change to a pedal. I got the pedal part, just don't have the mounting hardware to change it out. Maybe one day if I quit riding long enough I might do something. |
Posts: 135 Chesterfield, VA | I really like the pedal, and actually bought this one a year or so ago and had it moved over to my new Vision. I always felt like I was pigeoned toed when trying to brake with the stock peg. I guess it's all what you are use to and comfortable with...I also prefer a heel toe shifter and have had that on both my Visions. |
| Whatever works for you and a BIG plus if it helps save your life. |
| Oem works fine for my size 13s. I think my foot would get caught at the wrong time. It sure does look good. |
Posts: 8144 New Bohemia, VA | sarvbill - 2011-12-01 7:25 AM
I'd like to see what you've done Bill. Are you going to Victory of S. Md on the 10th? |
Posts: 849 , FL United States | 20 10 Vision - 2011-12-04 10:41 PM
Works good for my size 15 boots as well. |
| I have the Kuryakyn replacement ones on both the shifter and brake side and have not had any issues with finding the brake pedal when I need it...But, as said above, if it works for you use it.....Brakes are critical...... |
| PLEASE PLEASE if your going to use the Kuryakyn brake pedal sand the center pad slot or scratch and clean it really good before placing rubber in place.
Kuryakyn has had this part for years and the center rubber pad does not hold all that good and will come off. As far as I know they do not have a replacement rubber. Its a very nice looking pedal.
