Posts: 131 Edmond, OK 2012 Vision, 2012 Cross Country | If you are able to get out and ride for a bit this weekend double check your tire pressue. With the temps going up and down your tire pressure may choose to go down. So ride safe and be sure to check the pressure in both front and rear tires. Another thought, with the winter season coming fast, if you don't already have a battery tender to help keep your battery ready to go, ask for one for Christmas. It's not that expensive and something you could use as well. Ride Safe. |
