| Has anyone tried or succeeded at connecting up the temp sensor function of the PC-V ?
Posts: 3773 Pittsburgh, PA | I thought the temp setting only worked on harleys? |
| Arkainzeye - 2011-10-27 2:01 PM
As a plug and play option, yes... but I would think as long as we could tap the temp sensor on our bikes with the appropriate lead from the PC-V, there's no reason it shouldn't work.... surely someone has tried this?
| I'm in the process of getting the pieces together for a PCV w/autotune and think this has a lot of merit. Using the analog input and setting the temp/voltage from the CHT sender seems like it would work well. I have a infrared thermometer and a volt/ohm meter. My plan is to splice into the CHT, start the bike and take readings. I'm not sure of what the percentage of fuel increase should be but you play with that. Have you done anything along these lines? |
