Lloydz Adjustable Vision Intake
DannyB
Posted 2011-10-24 10:08 PM (#99820)
Subject: Lloydz Adjustable Vision Intake
2 mi from Jim Beam n KY
Anyone checked out the latest goodie from Lloyd?
alohaboy
Posted 2011-10-24 11:43 PM (#99823 - in reply to #99820)
Subject: Re: Lloydz Adjustable Vision Intake
Danville, CA
yeah, getting it installed in a few months. Looks clean..
Posted 2011-10-25 7:09 AM (#99829 - in reply to #99820)
I think this was just talked about 1-2 days ago? ?
DannyB
Posted 2011-10-25 8:18 AM (#99832 - in reply to #99820)
Brett, yeah, it clean looking and interesting. Be sure to let us know what you think.
Posted 2011-10-25 11:03 AM (#99841 - in reply to #99820)
says up to 8ftlbs added with this device, their last one had the same claims and it was less than $100.
Posted 2011-10-25 11:25 AM (#99842 - in reply to #99820)
So I take it that it goes on top of the EFI's and with different tube lengths you can very how much air your EFI's get
Am I thinking right? Now would there be a benefit to stock motors?
Posted 2011-10-25 1:17 PM (#99852 - in reply to #99842)
john frey - 2011-10-25 11:25 AM
i was wondering that as well.. then i also thought since there would be 2 air filters. but only 1 adjustable one. how does that effect the venturi effect and air flow of the other air filter? i mean how much air can the intake really suck in ? we know 2 air filters help over 1. but 2 air filters when only one is adjustable.? just wondering...
wroman
Posted 2011-10-25 11:56 PM (#99897 - in reply to #99820)
Gettysburg, 2008 Tour Premium
I may be wrong here but this is not an air cleaner. I am under the impression that it mounts on top of the throttle butterfly's within the frame air chamber and below the secondary air cleaner if you have one. By causing a restriction from 45 to 41 mm you should be able to increase the velocity of the air at lower CFM to have the power come on sooner and therefore boost low RPM power at the expense of higher RPM power. I am waiting to see the reports of benefits to stock uncammed bikes and see if cammed bikes report more juice lower in the powerband. One thing keeping me from cams is their powerband advantage starts at 2700 RPM, this could be a game changer.
