Posts: 2300 Georgia, west of Atlanta | Anyone have a 116 Lloyd engine with 30,000 miles on it ?? Just wanting to see what little gremlins might pop up with a engine making 155 HP at the crank and what it's doing to trannys, clutch plates and baskets. |
Posts: 284 mansfield, MA United States | I have almost 20k now. The clutch is a problem right now but that was not unexpected. I am getting some slipping in high rpm's.It just started but I will be installing a Veriable pressure plate at some point. But I would do it again!!!!! I love it! |
Posts: 216 Danville, CA | Hey Fred,
Question for ya? Is the IAC really needed with all the rest of the mods you have done? I ask because I am going to take my 12 vision in this winter and put the 116 package on like you have. Thanks for the feedback.. |
Posts: 284 mansfield, MA United States | To be honest. I have no idea. It was done when I had everything else done. But I get very little popping. |
Posts: 2300 Georgia, west of Atlanta | fastfred do you have the Barnett plates and pressure plate installed currently ?? |
Posts: 39 Georgia | What about the S&S clutch that increases the clutch pressure based on the speed or rotation of the clutch....Lloyd does this install and its really quick and easy......pull your clutch basket and ship your basket and primary cover to Lloyd. Once he receives he can build the clutch and clearance the primary and then ship back the same day. I don't know the technical terminology for this style clutch but I do know how it works. :0 It is suppose to be superior to the Barnett clutch although based on your clutch's conditions, some parts of the Barnett clutch may be required as replacement parts. |
Posts: 58 San Clemente | cryptodogg - 2011-10-24 4:21 PM
The technical term is variable, which he said he was going to do. |
Posts: 284 mansfield, MA United States | I was told that the Barnett Billet Clutch Plate won't fit the 2011 and up. They put in the green spring and it works ok but at high rpm's I get slipping. I knew I would. Not a hard fix I just haven't had the time to do it. But the 116 runs good.
Edited by Fastfred 2011-10-25 6:51 AM
